W/NG Box X1CPBL Query
D Turner
Post by D Turner »
Hi...
Just going through my new purchase and have a query re my gear box. (hopefully this should be here)?
My gearbox codes seem to show a "B" for balloon tyres. Would that be correct for a military bike?
Also, whilst I'm here. I'm assuming this is a non drain plug box?
Thing is, there seems to be a fair amount of condensation in it, judging by the milky white residue dripping out after a run :(
Re: W/NG Box X1CPBL Query
You are correct, the B denotes balloon tyres but don't worry this is standard it merely means that the gearbox sprocket is a bit further out and that you can fit up to 4.00 wide tyre. The box appears to be correct for a W/NG the X denoting oils seal fitted and a lack of speedo drive. Your clutch arm could do with adjustment so that it is the position it is now when it is half way through its travel, slacken cable, screw in push rod adjuster and adjust cable.
D Turner
Post by D Turner »
Thanks very much.
Regards the clutch arm. Judging by the amount of white froth dripping from the box I'm going to have to strip it down and clean it out. I've already made some grease/oil mix to re fill it.
I've seen a video whereby someone did that with the box still in the frame. Any advice on doing it that way would be gratefully received.
The drain plug was introduced during the W/NG phase but even a grease and oil mix is too thick to drain through a small hole. You will have to open the box up and use an old desert spoon to scoop the grease out, it's what I use. Much easier to put the grease in, or as much as you can while it is open, rather than through the filler plug. White Spirit seems to be the best for cleaning the grease off, warming it up doesn't really work.
D Turner
Post by D Turner »
Thanks again. I'll let you know how I get on.
