Brake "wedge holder"
Pictures (or stories) of hideous injuries sustained by your Ariel
Re: Brake "wedge holder"
Post by JohnnyBeckett »
hi , i think some classic cars use the same size brake adjuster maybe a old three wheeler ect :?: i have a alloy one with the adjuster thread striped that i am going to see if i can recoil it
Chris Sealy
Post by Chris Sealy »
I have received my "wedge holder" from Dragonfly. It appears to be a very good quality brass casting, properly machined; except for the studs being approximately a half millimetre too close together. I have not assembled the brake yet to check any other dimensions. I have filed the brake plate stud holes to allow it to fit. Others, of course may not have a problem. I am posting simply to warn that fitting the part may not be the proverbial "five minute job".Cheers, Chris.
nadab_sardar
Post by nadab_sardar »
Worth checking your cracked ones closely before you refit them. If it's die-cast (Mazak/pot metal), cracking like that only gets worse, and a wedge holder letting go mid-stop is the last thing you want. Same goes for any that look okay but are a bit crumbly round the stud holes.
On sourcing, I'd ring Drags rather than trust the website listing, as Simon says. If they can't supply, it might be worth posting in the Wanted section of the club's classifieds too, since a few members seem to have found brass ones at autojumbles over the years.
For the cam, a lot of the 4115-46 ones I've seen get sold on as part of a complete brake plate assembly. A spare plate with a worn shoe lining is sometimes cheaper than hunting the cam on its own, and you end up with spare bits as well.
High zinc content MAZAK expands with aging, as well as becoming brittle and cracking. If there's ANY doubt with the Ones you have get rid of them. Brakes can be your life. That stuff is Muck metal..Nev
