Can I just double check that there aren't ant thrust washers or shims in the gearbox (Layshaft, mainshaft or gear selector mechanism)?
None fell out when I opened it up (to clear out the foaming goo) but that doesn't mean they shouldn't have been there. Research I have done seems to say no but want to be sure before reassembly.
TIA
Dave (From sunny Bournemouth if anyone is local)?
Thrust washers/shims
Re: Thrust washers/shims
Shims are not used as standard.
Thanks.
Glad you said that as I've just put it back together without any. (Not that I had any to fit anyway.).
